ARB install
Western Slope, CO
Fellas,
I've tried to look for the tech write up on installing an ARB locker in an fj40.
Technical Links, FAQ's in the 40 section etc, can't find it.
In particular I need to know the backlash for the Ring and Pinion.
Like a dumbass, I took the ring out without checking the backlash first.:whoops:
Thanks,
http://www.ih8mud.com/tech/arb.php
Tech link.
I did not have any problems with mine..........Poser is doing it:D
Ed
The only backlash I had to deal with is when my wife found out about it.;)
I think that max was .011" so Steve's recommendation is perfect.
You're using your original gearset, right? The side gear setup is easy. It's getting the relations between pinion and ring right that causes people problems.
Ed.........it's a safety item. Tell her that :)
Honk,
Thanks for that additionally info. This will help out.
Yes, I am using the originaly gear set. I have not take the pinion out so I should not have that much of a problem.
BTW, nice stable of Cummins. Dad's got a 2004 3500 TD SB that I drove while I was rebuilding the tranny. Didn't want to give it up.
Jim
Thanks guys for all the help.
I had a good result today. A Bluegrass Cruiser member already had the locker in the pumpkin and the lash was .004" just by feel and sight. I adjusted to .005" then tighted down the bearing bolts.
Well after that I measured again and we were back at .004". For some reason it moved 1/1000th after tighting the bolts. So I loosened and adjusted to 7/1000th. Torqued back down and I returned to 5/1000's.
Thanks again for the spec's.
