ARB front bumper question
Southern Maine
I have a 95 that I'm shopping for a non-winch(mine's in back) ARB for, but the ones I see in the pics all extend out to the fender flares. I'd like to pull what's left of my flares and get a bumper the right size for a flareless truck. I know the part number for the regular non-winch bar is 3211050, but don't see one for a flareless truck.
Is there one that size or can one be bought that fits? Part number?
Or is it a cut and weld mod job on the stock ARB and if so how bad is it to do?
Thanks!
The commercial arb bar for the 80s is a bit narrower and lines up with a flareless body. Don't have a part number for you and I believe it may be avail as winch model only. Good news if you wish you can sneak an 8274 in that model easier
I "think" the industrial ARB spaces away from the grille a little bit more to allow the 8274 Warn to be mounted. In any case, the 8274 will bolt up to it.
The original 80 ARB is set up for the old Warn M10000, but obviously fits most planetary-type winches. . IIRC, it can be modified to accept the 8274, but requires some work to do so.
Pics please, before I spend my money!
I run a standard bumper with no flares. Doesn't look bad IMO. No pics right now, I'll try to get some tomorrow.
Here ya go
Yeah, if you're flareless, that looks a lot better.
PM me your cell # and I will shoot some for you tomorrow. I will not be able to upload photos here again until Monday.
My phone is actually only a phone-call-making-kinda-phone and not connected to any wifi or smart or anything like that. Hard to imagine these days, but there it is. The phone store guy couldn't believe that I only wanted a phone for making phone calls and nothing else...sign of the times I guess.
Tromz, that looks a lot better than I thought it would, thanks for those pics! That helps a lot!
artech,
BTW, I think you may be correct in that there's no non-winch versions of the ind ARB available here in the US. I vaguely remembering seeing that was the case in looking up parts or something one time. Slap a plate on it and call it good is one way to deal with that big hole if you won't be sticking a fairlead on it.
Looking at the pics, the ind ARB looks a little deeper in the winch mount area os that a 8274 would drop in, but the angle is isn't good. Maybe Tromz can confirm I'm seeing that right or just need new glasses? That deflared LX sure looks good.
IIRC the 8724 doesn't clear the grill. Idk if your gonna add the weight and less clearance of the ARB might as well just get a 12k winch.
I have a Ramsey Re12000 worm drive winch sitting in the garage right now that is going under the rear end, similar to what 98snakeeater did with his rear winch. It's a brute of a winch and I don't think there's many bumpers that would take it without some reworking, it's quite large and the mounting is different. Every time I have gotten stuck I was pulled out backwards so I could try a different line, and I like that if I'm winching someone else the high-pinion front diff won't be an issue on a rear-mount setup. So I'm looking for a non-winch front bumper.
And we have quite the whitetail deer population up heah and I just changed over to working nights, so I'm having near-misses frequently on my morning commute home. Whitetails are pretty big animals, averaging around 150 pounds with the big ones going up to about 220 or more. I think the ARB is the one I want more for the animal-strike protection than for ground clearance, which I don't have much of anyway because my truck isn't lifted. There are some off-camber trails in my area that are quite unfriendly to lifted trucks, one that I frequent has one section that is every bit of 30 degrees of tilt by my inclinometer. It's the same in both directions so I believe that is a true measurement. That's last fall, and it might be worse now after the spring thaw. That's a rig-flopper right there. I've helped recover a wrangler and a cherokee out of that spot, both were jacked up pretty high and both tipped on their sides. So, no lift for me thanks, I'm on spacers over my tired stock springs to get back to factory height. I may have to change out my springs with the new winch and bumper, but I want it to still be close to factory height when it's all done.
I just decided to pull my flares after I found out that the inspection law states only the tread has to be covered, but the sidewall can stick out past the body. This works for the size tires I'm running and I had one flare blow right off on the turnpike a while back, so the rest are coming off too as soon as it warms up enough to work in the garage on my nights off. Then a new front bumper, then fabricate a new rear winch mount and skidplate for the winch, then fabricate a rear bumper to work with the rear fairlead, then check the ride height with the added weight and see about new springs. (And a monstaliner paint job as soon as someone figures out how to tint it close to the factory dark green color.) That's the plan, anyway, and like all plans it probably won't survive first contact, but at least there is a plan in place.
Well, that's the why of it, and thanks to everyone who posted up pics. I was concerned that the bumper ends would stick out and look awkward without flares to line up with but I see that that really isn't the case. And who knows, if I ever do decide to run bigger tires I'll need to put the flares back on to be inspection-legal in this state, so maybe it'll all work out in the long run anyway.:D
