I have the CKMA12 compressor on my rig, solely setup to run my front and rear lockers. It has been working flawlessly for the past nine months. I typlically engage the lockers at least once a month for exercise.
Today I was wheeling to the upper part of my property on a 25% grade dirt and branch covered path which is best done with the lockers engaged. About 150 feet up the hill, my compressor came back on, and kept on. My lockers stayed engaged, so there was still pressure in the system. Once at the top of the hill I turned off the lockers, and the compressor kept churning on. The only way to turn it off was to switch the compressor off.
So, my thought is that the Pressure Switch has gone south, as the solenoids checked out OK when testing them separately. Also the lines do not appear to have any leaks.
Not sure if cleaning makes any sense. Nothing in the manual points towards it being serviceable. Anything else I should check before contacting ARB for a replacement, which should be under warantee.
Steve
Steve
