ARB compressor issues. New harness, and it's still not working. With Video. HELP!!
First things first, why am I in the 80-series section when I drive a 60? Because this section is larger, I figure I can get an answer quicker. It's a universal question.
My ARB compressor failed to turn on a few weeks back, and when the isolating switch was left to "ON", sometimes it would kick in every once and a while for a few seconds. I tried troubleshooting the system, and looking at the state of the harness I decided to find a replacement.
With my new ARB harness hooked up, when I turned "ON" the isolating switch the compressor ran for about 20 seconds, then shut off. When I flipped my front and rear locker switches, nothing happened; and when I shut them off I did not hear the "pftshh" of air releasing from the locker solenoid valves. It was almost like the compressor just ran for 20 seconds and then called it quits, and either my lockers are not engaging, or the compressor has not produced enough psi to do so.
I then took 12v directly to the compressor and it ran as it should. I let it run for about 10 seconds then cut the power to it. I re-hooked up my harness, checked all the connections, and tried again; but this time it wouldn't run at all when I flipped the isolating switch ON and OFF repeatedly. I replaced the relay as well. The only thing that I'm leaning towards at this point is the pressure switch. When the isolating switch is ON, the pressure switch has 12v, and when the isolating switch is OFF, the pressure switch has no power. Also, when I was going these tests I had the orange and blue wires that go to IGN and ILLUM hooked directly to the battery, so everything that should see 12v had it.
Does it sound like a pressure switch issue?
It is an RDCKA 12V on a BJ60.
