arb compressor install ?
hillbilly desert rat
Hi All
I am looking at the wiring diagram and there is a sw 1 a sw 2 and a isolation sw the isolation switch that is for the comp sw then sw1 ,, sw2,, those then go to the lockers also I want to have a air line for tire inflation etc.. how do i make that happen I did buy the comp with the mini air tank .. Just dont know how to pipe it in Thanks for any info
decavo
The best thing would be to get Slee's manifold. Pipe the compressor to the manifold, run the solenoids, pressure switch and air line hokk up fitting from the manifold. It will make for a clean set up.
These pics show the manifold with the solenoids and pressure switch, then the compressor mounted behind the brake booster. The coiled copper line connects the compressor to the manifold. If you look at my manifold it has a 1/8 NPT plug where you could plug in your air fitting.
decavo said:
So how are you mounting the manifold through the fire wall with tex screws or what ?? Also will this little air comp really blow my tires up ???
I used nutserts to bolt it to the firewall-easy. This compressor is not reccomended for general use like blowing up tires. I use mine for lockers only. It would be very slow for tires anyway.
