Anyone using this product?
Panama City Beach, FL
With all the talk of fuel costs and fuel savings I was wondering if any of you had used this product or have ever heard of it.
www.cermetlab.com
This company is wanting our company to sell this product and I'm just looking for other comments about it..... as I trust you guys about everything you say.....:D:flipoff2:
Thanks!
TC
A good salesman should use the products he sells. Why don't you try it out and give us a report?
How is it applied?
It's sold on Overstock.
CerMet Ceramic Coating Nanotechnology (10 ml) from Overstock.com
Some claims made:
CerMet helps you protect your largest assets and begin saving fuel and reducing harmful emissions
I especially like these two.
  • 10ml for use up to 10 quart oil systems
  • 30ml for use up to 30 quart oil systems
  • 50ml for use up to 50 quart oil systems
CerMet lasts an incredible 60,000 miles
So if you change your oil at 5k intervals, 10ml (actually would be ~7.5ml) is going to survive 12 oil changes (90 quarts of oil)? :lol:
CerMet is not your typical snake-oil-additive, it is not a lubricant
CerMet is a metal surface ceramic coating and conditioner that only uses the oil as a conduit to reach the friction zones in which it coats
Using CerMet will help you receive all of the benefits of a ceramic coating including: reduced friction, corrosion, vibration and heat, renewed and protected metal surfaces, increased part life, and increased overall efficiencies
So it's not a lubricant, yet reduces friction? :rolleyes:
CerMet is a patented revolutionary ceramic coating nanotechnology that will help restore and protect your engine parts without disassembly or downtime
So you can put it into an engine with a blown HG and it'll magically fix it?
(Worth repeating.)
This statement is perfectly true. It's not typical. It's a more esoteric form of snake-oil-additive.
Thanks, but no thanks....... after reading some of the other posts above.... They offered to send me some..... That's why I turned to the experts here.... I'm just a :banana: maybe :banana::banana: dude..
TC
Plus if I blow my engine I can't get to all your redfish spots down there in LA :D
I have a news flash for the folks that sell this stuff. Let's say it bonds to the metal, right? Um, the metal parts in your engine NEVER, EVER touch each other. NEVER. There's always a layer of something between every metal part. Hmm, what could that be....? It's on the tip of my tongue.....<snap> ..OIL!
The whole point of engine oil is to provide a constant film of oil between hard working hot metal parts to cushion them from EVER touching each other. Let 'em touch each other dry and you'll have instant and fatal bearing damage in seconds.
If you actually have metal to metal contact in your engine, this product will help but I have to say if that is the case your engine is toast or about to be. Same with the Slick 50 product - it will do amazing things in an engine without oil (as amply demonstrated in those cool videos). But in a normally operating engine with proper lubricant your benefit is precisely and exactly - zero. As in zip, nada - no benefit.
Any questions?
DougM
So, you have seen the Slick 50 videos...
I rest my case. Magic.
Yes, and they are complete bull crap.
Chapter 10 - The Infamous "No Oil" Demo
At at least three major motorcycle rallies this past year, we have witnessed live demonstrations put on to demonstrate the effectiveness of certain oil additives. The demonstrators would have a bench-mounted engine which they would fill with oil and a prescribed dose of their "miracle additive." After running the engine for a while they would stop it, drain out the oil and start it up again. Instant magic! The engine would run perfectly well for hours on end, seemingly proving the effectiveness of the additive which had supposedly "coated" the inside of the engine so well it didn't even need the oil to run. In one case, we saw this done with an actual motorcycle, which would be rid den around the parking lot after having its oil drained. A pretty convincing demonstration - until you know the facts.
Since some of these demonstrations were conducted using Briggs and Stratton engines, the Briggs and Stratton Company itself decided to run a similar, but somewhat more scientific, experiment. Taking two brand-new, identical engines straight off their assembly line, they set them up for bench-testing. The only difference was that one had the special additive included with its oil and the other did not. Both were operated for 20 hours before being shut down and having the oil drained from them. Then both were started up again and allowed to run for another 20 straight hours. Neither engine seemed to have any problem performing this "minor miracle."
After the second 20-hour run, both engines were completely torn down and inspected by the company's engineers. What they found was that both engines suffered from scored crankpin bearings, but the engine treated with the additive also suffered from heavy cylinder bore damage that was not evident on the untreated engine.
This points out once again the inherent problem with particulate oil additives: They can cause oil starvation. This is particularly true in the area of piston rings, where there is a critical need for adequate oil flow. In practically all of the reports and studies on oil additives, and particularly those involving suspended solids like PTFE, this has been reported as a major area of engine damage.
The FTC filed a complaint against them for false advertisement and they settled with the FTC.
Quaker State Subsidiaries Settle FTC Charges Against Slick 50
Agreement Safeguards $10 Million in Redress to Consumers
Three subsidiaries of Quaker State Corp. have agreed to settle Federal Trade Commission charges that ads for Quaker State's Slick 50 Engine Treatment were false and unsubstantiated. Under the terms of the settlement, the companies will be barred from making certain claims and required to have substantiation for claims about the performance, benefits, efficacy or attributes of their engine lubricant products. In addition, the settlement will preserve the Commission's option to seek consumer redress if class action suits currently being litigated against Quaker State and its subsidiaries result in less than $10 million in consumer redress.
The three Quaker State subsidiaries named in the settlement are Blue Coral, Inc., Blue Coral-Slick 50, Inc., and Blue Coral-Slick 50, Ltd. Blue Coral, Inc., is based in Cleveland, Ohio. Since its 1978 introduction, Slick 50 has about 30 million users world-wide and retails for about $18 a quart. The company claims to have about 60% of the engine treatment market.
In July, 1996, the FTC issued a complaint against four now-defunct Quaker State subsidiaries, which have been succeeded in interest by the three subsidiaries named in the settlement. The FTC's 1996 complaint charged that ads for Slick 50 claiming improved engine performance and reduced engine wear were deceptive. According to the 1996 complaint, Quaker State's subsidiaries aired television and radio commercials and published brochures carrying claims such as:
--"Every time you cold start your car without Slick 50 protection, metal grinds against metal in your engine";
--"With each turn of the ignition you do unseen damage, because at cold start-up most of the oil is down in the pan. But Slick 50's unique chemistry bonds to engine parts. It reduces wear up to 50% for 50,000 miles";
--"What makes Slick 50 Automotive Engine Formula different is an advanced chemical support package designed to bond a specially activated PTFE to the metal in your engine."
According to the FTC complaint, these claims and similar ones falsely represented that without Slick 50, auto engines generally have little or no protection from wear at start-up and commonly experience premature failure caused by wear. In fact, the complaint alleged, most automobile engines are adequately protected from wear at start-up when they use motor oil as recommended in the owner's manual. Moreover, it is uncommon for engines to experience premature failure caused by wear, whether they have been treated with Slick 50 or not, according to the FTC. Finally, the FTC alleged that Slick 50 neither coats engine parts with a layer of PTFE nor meets military specifications for motor oil additives, as falsely claimed.
The FTC complaint also charged that Slick 50 lacked substantiation for advertising claims that, compared to motor oil alone, the product:
--reduces engine wear;
--reduces engine wear by more than 50%;
--reduces engine wear by up to 50%;
--reduces engine wear at start-up;
--extends the duration of engine life;
--lowers engine temperatures;
--reduces toxic emissions;
--increases gas mileage; and
--increases horsepower.
In addition, the complaint alleged that the company did not have adequate substantiation for its advertising claims that one treatment of Slick 50 continues to reduce wear for 50,000 miles and that it has been used in a significant number of U.S. Government vehicles.
Finally, the complaint challenged ads stating that "tests prove" the engine wear reduction claims make by Slick 50. In fact, according to the FTC complaint, tests do not prove that Slick
50 reduces engine wear at start up, or by 50%, or that one treatment reduces engine wear for 50,000 miles.
The agreement to settle the FTC charges bars any claims that:
--engines lack protection from wear at start-up unless they have been treated with Slick 50 or a similar PTFE product;
--engines commonly experience premature failure caused by wear unless they are treated with Slick 50 or a similar PTFE product; or,
--Slick 50 or a similar PTFE product coats engine parts with a layer of PTFE.
In addition, the agreement will prohibit misrepresentations that Slick 50 or any engine lubricant meets the standards of any organization and misrepresentations about tests or studies.
The settlement also prohibits any claims about the performance, benefits, efficacy, attributes or use of engine lubricants unless Quaker State's subsidiaries possess and rely on competent and reliable evidence to substantiate the claims. In addition, it prohibits the Quaker State subsidiaries from claiming that any other Slick 50 motor vehicle lubricant reduces wear on a part, extends the part's life, lowers engine temperature, reduces toxic emissions, increases gas mileage or increases horsepower unless they can substantiate the claim. The subsidiaries also will be required to notify resellers of the product about the settlement with the FTC and the restrictions on advertising claims.
Finally, the agreement holds open the option that the FTC may seek consumer redress. If the private class action suits against Slick 50 currently under litigation do not result in at least $10 million in redress to consumers, the agency reserves its right to file its own federal district court action for consumer redress. In addition, the FTC has reserved its right to seek to intervene in any class action suit to oppose a settlement it believes is not in the public interest.
The Commission vote to approve the proposed consent agreement was 5-0. A summary of the agreement will be published in the Federal Register shortly and will be subject to public comment for 60 days, after which the Commission will decide whether to make it final. Comments should be addressed to the FTC, Office of the Secretary, 6th Street and Pennsylvania Avenue, N.W., Washington, D.C. 20580.
NOTE: A consent agreement is for settlement purposes only and does not constitute an admission of a law violation. When the Commission issues a consent order on a final basis, it carries the force of law with respect to future actions. Each violation of such an order may result in a civil penalty of $11,000.
Copies of the complaint, consent agreement, and an analysis to aid public comment are available on the Internet at the FTC's World Wide Web site at: Federal Trade Commission - Home and also from the FTC's Public Reference Branch, Room 130, 6th Street and Pennsylvania Avenue, N.W., Washington, D.C. 20580; 202-326-2222; TTY for the hearing impaired 1-866-653-4261. To find out the latest news as it is announced, call the FTC NewsPhone recording at 202-326-2710.
Media Contact:
Claudia Bourne
Farrell Office of Public Affairs
202-326-2181
Staff Contact:
Elaine D. Kolish or Mary K. Engle
Bureau of Consumer Protection
202-326-3042 or 202-326-3161
(FTC File No. D09280)
Fred
Why do non-believers always spew such "fact" filled hatred?
Slick 50 was magic. Haven't you seen how slick teflon pans are compared to bare metal? Any idiot can see that a fine film of polytetrafluoroethylene (PTFE, or teflon) makes the engine magically slick. What is it that you don't understand?
Magic.
Magic.
Well I didn't know I was getting a magic engine! :eek:
He's either silly or trolling.... ;)
Even Dupont says that it's not for use in nor will work in/with engines.
If it worked, EVERY engine manf. would precoat the internal part of their engines and, poof, magically have no warranty worries ;)
As already mentioned, there is/are no metal to metal contact points in an engine.
He's simply fishing.....
Fred
I like fishing, but none of that pansy trout stuff for me. Gimmi a big ol' smallie or large mouth any day.
And when did this thread turn into chat? :hillbilly:
