anyone installed SROR sliders?
Charleston, SC
I got my sliders from Jim and they look great, just can't figure out how to mount them and no instructions. There are three plates and a bunch of different bolts. Some of the plates have screws welded, some don't and don't know where to mount it to. The holes don't seem to line up with any frame holes. If anyone has these and could help or has pics of how mounted, would be greatly appreciated.
p.s. - don't forget to call the people you know who served and tell them thanks, it will mean a lot
Fairly self explanatory...
Passenger side on the 97
Take out the rear bolt on the front lower control arm and put the new longer bolt in then mount the slider up on what is left of the bolt. The middle plate uses the two small bolts which go right in to the two existing holes on the frame rail. The rear plate gets sandwiched with one of the flat plates.
Driver side is another bolt on the lower control arm, sandwich in the center (the brake lines need to be loosened so you can put the plate between the lines and the rail, the rear is a pain in the ass sandwich.
