Anyone have these?
In the shop cuttin' parts
Website
www.greatlakeswaterjetinc.com
7" Mega Lift Coil Kit
This 7 inch coil kit by Mega Lift is perfect for those chasing big flex with a smooth ride.
Complete with 2 x front and 2 x rear coils, powder coated Mega Lift blue to prevent corrosion.
Note - In conjunction with a wheel alignment the fitting of Caster plates in the front control arms, extended brake lines and adjustable panard bars front and rear will be required.
Product Code: ML07TL7FR
RRP inc GST: $650.00
http://store.snakeracing.com.au/cache/item-1117public.html?cache=no
Or these?
Cruiser Dropped Radius Arms
80 Series Cruiser owners can now go all the way with large lifts with the use of Snake Racing's "SuperFlex" Dropped Radius arms.
"Superflex Dropped Radius Arms" are cast in steel & designed to fit the 80 Series Cruiser fitted with 4 inches or more lift. The fitting of the arms will correct many issues relating to a lifted Cruiser including the main problem being correct steering geometry.
(no more caster plates or bushes needed when the arms are fitted) No more clearance isssue with the Tie rod hitting the top of the radius arms
The front axle is also moved back to factory specs, a lifted truck will shorten in the wheelbase when lifted.
Product Code: TOY80DRA
RRP inc GST: $1400.00
http://store.snakeracing.com.au/cache/item-1706public.html?cache=no
Nope, never seen em'. Cool to have another option though. THanks for sharing. $1,400 is really expensive. Is that in some other currancy?
Its in Austraila. Don't know what the exchange rate is. Anyone from Assuie?
nice arms but mucho $$$
