Anyone else with a 2010 LC unable to locate the TPMS set switch?
MD
Mine is not where the manuals say it should be, i.e., next to the hood release. TIA.
Really stick your head under there with a flashlight. That button looks like a little valve stem cap almost and is very inconspicuous. It is also not facing out at the same angle as the hood release but is more perpendicular to the floorboard if I remember correctly.
Pic for reference:
A couple more pics just for good measure:
HTH
well now I feel dumb but i found it. Now to get the pressures right on the new tires.
If you tell me what your new tires are, I might be able to help you with a recommended cold tire inflation pressure ...
Since you're offering kind sir how about 275-70-18 Toyo MT'S please
If you mean the LT275/70R18 (33x11.00R18) 125P Load Range E Toyo Open Country M/T tires on a 200 series Land Cruiser, then the Recommended Cold Tire Inflation Pressure is 41psi Front/Rear.
HTH
HTH
Thank you sir
