Any tricks for this?
Bozeman, MT
Howdy,
Installing my mini-truck PS conversion today and hit a snag. I can't get to the backside of the bolts for the new gear box bolts for the life of me.
My header is in the way, so...
if I remove/loosen my headers (which I hate to do since they actually seal) would I need to install a new gasket(s)? Or could I get away with some more copper gasket spray and retorque the header/intake bolts up?
Any other tricks to get you fingers in there?
Thanks in advance!
Rezarf <><
ITS PITA for sure DUCT TAPE worked for me ............. after I fished out the fiber nut's out of the frame for the 10th TIME ..........! DID YOU REMOVE THE FENDER ?
drew, you would need a new gskt IMHO.
whats the deal, you can hold the nut to start the bolt?
i think dusty had it, put some tape on one side of a boxed wrench, and press the nut in the wrench so the tape holds it....GO!
Thanks guys-
Two wrenches duct taped together and fed in through the frame, with a lot of effort and 4 hands, and in they went.
The PS is cooler than I thought it would be.
Rezarf <><
Thanks Poser!
It is hard to believe I waited that long, but it is great.
Rezarf <><
Rezarf
Any pics of the conversion? Any tips?
I have read about everything there is to read, got almost all the parts (still need pulley and a couple other things), and am about ready to do it in the next month. I've seen Romer's thread, and it was very helpful.
cessna170b said:
Rezarf
Tips-
Have an extra set of hands on deck.
Have all the parts in order before starting.
Have a cut off wheel.
Soak everything with rust eater before starting (days out)
Have heat on hand.
I put my pulley in the oven at 200 degrees, and my bushing in the freezer and that allowed me to get a better seat than anything else.
Check out my post on getting the pitman arm off.
No real pics, it went pretty easy.
I have a few NAPA part numbers if you need 'em for the belt, and Sag cap.
Good luck it should be fun!
Drew
