Any steering problems????
Corpus Christi/Austin, Texas
Hi all,
I have a 64 fj40 that im putting 4in spring lift(HFS) and shackles 3 inches longer than stock. So with that type of lift do I need to alter the steering any. Also it has the minitruck power steering conversion on it. I think i can run 35s?
Thanks,
my64fj40
I think you are going to need to run some serious caster shims in the front or you will have some really scary wandering steering. The reason is those 3in. over stock shackles on top of the 4in lift. And yes you should easily be able to run 35s with that much lift.
Sorry, still a newbie, but are caster shims those the shims that go between the spring and ubolt plate??
They are shims that go between the springpack and the spring perch on your axle. Get steel ones as aluminum will flatten and make your ubolts loose and react with the steel. Bad news, BTDT.
This guy can make you some in any degree you want and you will find his site a wealth of knowledge. http://www.4crawler.com/4x4/ForSale/Shims.shtml
Toyo FJ40 said:
Don't you have to put a longer center bolt in the spring pack so it will reach through the shim?
Kevin
A friend of mine used a hardened and welded it to the center bolt with some sort of special weld.
Well yeah..it's a Cruiser.. I haven't had it on the road since I finished it (still doing the top and doors). Been driving it on the dirt road I live on and it does wander but I still want to change out the tie rods and I think it needs an alignment since I swapped out the front axle for a 78 axle with disk brakes.
Kevin
