Any real need for carpet padding?
SteveNJ
PO removed everything, dynamated and then laid down 1/2 inch dynaliner (thick foam padding). He left the ratty padding on the carpet and there were a lot of fit issues.
I'm about to replace with a new to me properly colored carpet (to relplace the one he painted), I'm thinking with all the padding I have already I can just scrape off the ratty OEM padding stuck to the carpet and things should fit a bit better than they used to.
Is there any actual use for the lining if one is already laid down? (I'm guessing no, but it pays to check)
I think it is just sound absorber.
I agree. If the heat and noise aren't issues with the dynamat down, you're probably good. Take the stuff out, install the carpeting and give it a test drive. if OK, then pitch the padding.
I took out the carpet and padding from my 60. Ugh. Wish I'd left the ratty stuff I had in there. Heat and noise for sure.
