Any issues mounting bluesea fuses here?
San Diego
Are these bad spots to mount my fuses? I dont really know how to fab up mounts like many do on here. So for those that havent made their own mounts where/how are you mounting them?
I mounted mine on the fire wall and on a bracket I bent out of aluminum. Don't recommend putting the bus on the relay cover as it will be difficult to access the relays without pulling the cable going into and leaving your bus.
That's not a bad spot, but I'd pick the firewall as well, keeps them higher and dryer. I would also keep the bus off the relay cover.
If you screw that down to the relay cover you are asking for moisture intrusion to the circuits below. Like others said, it will also be a pain to access under the cover.
I used 3M tape and stuck it on the Charcoal can. Works fine. Battery box, cruise control box and upper firewall are common spots.
Here is mine
I mounted mine in the same spot (first pic) 5 years ago on one truck and 2 years ago on another. No trouble thus far. Unlikely you will have moisture moving from the top downward that high up in the engine bay. If so I would be more worried about your distributor. You could always use heavy duty double stick tape if its still a concern.
I placed mine the same as your first pic as well...3 years ago with no issues to date.
