Antenna plug for fender
Lake Stevens, WA
I am tired of bending/breaking the antenna on my LX. I know all about the fix on the new mast, but I feel that it is just going to keep breaking/bending. I would like to find a plug for the hole in the fender.
I am going to be using the CB antenna for the radio with the firestik adapter. I have used the search on here, but, have not found any definitive answers. I was just wondering if anyone had any ideas on where to find one.
Thanks,
Jon.
I'm in the same boat. I went to an in vehicle antenna that works pretty well. If I can't find a plug, I may just weld in a patch panel and repaint the fender.
Serious thread revival warning...
Did you ever find a solution? I'm going to go with the firestik and my bumper mounted CB antenna.
There are plugs available- not sure where- but I've seen them on others trucks.
What I did was this:
I removed the fender and epoxy'd a large fender washer under the hole. Then I covered the remaining 'hole' with body filler and sanded until it was smooth and followed the contour of the fender. Then I painted it.
You literally can not see where the hole was.
I am currently using my firestick for my radio as well. The change occoured when I installed my JDM snork.
I'd just got to Motormite, aka HELP! section at the auto parts store and find a trim plug big enough to cover the hole. Then pick a washer with a small enough hole to accomodate the plug tightly but big enough in diameter to cover the hole from inside the fender.
Add a dab of silicone under trim plug's lip.
Yeah- but I already had the fender off to cut the hole for the snork anyway- so half the work was already done.
