Antenna mast replacement...
Austin, TX
made easy. This is for the 91-92, but I also think it's valid up to 95 models. Buy PN#86338-60040, rod & pipe shield. If you don't have the female threaded end which is inside of your old mast and can't find one, this won't help. I was lucky I have a parts truck and saved the old broken mast.
What you need is the threaded piece that is inside of the old mast, it's female threaded on one end and crimped to the plastic riser cord on the other. I used wire cutters to cut the antenna shield back to the bend in the mast to gain access to the threaded portion, which also reveals the very end of the plastic cord. If you need to cut the riser cord, cut it as close to the end as you can, reattaching is pretty simple. Unscrew the riser cord from the mast, install new mast then reinstall bushing on the fender and keeper to the antenna motor.
For those of you like me, whose mast and cord were broken, find a broken mast which still has a threaded tip. As mentioned earlier, I was lucky to have one, but I bet you could find a Toyota in wrecking yard and clip the mast and cord off a car with a power antenna and it'll work just fine. When splicing is necessary at the end of the plastic riser cord, melt the old portion out. Then heat the metal tip and slip it over your old cord. You will need to cool it pretty quickly, so have some water handy, I used beer, YMMV. Trim any excess plastic away so it can slide up into the mast freely then screw the newly spliced tip to the new mast. Reinstall the bushing over the mast to the fender, and the keeper to the antenna motor. Done.
I couldn't tell you how much of the plastic riser cord you are safe to cut, I had no idea how much I had to start with, but I have a full range of antenna after splicing.
If you broke your fender bushing or keeper, I may be able to help you out.
What type of cord did you use. I tried this on my '91 today. Had the cord but only about a 20" length. Doesn't feed into the motor, which I can hear running both on up and down.
Also, what did the mast run you?
Don't know on the price, it was a christmas present, but it is OEM Toyota. Maybe contact Cdan at American Toyota. I didn't mess with the cord other than splicing the tip on to what was left, which was 25-30 inches??
I've no idea what to do if you pull the cord loose from the motor, but I can rip apart a motor to find out. I cut the cord on my parts cruiser b/c I cared not what happened to it.
