Antenna mast replacement questions
Morgan, Utah
First off... new to the forum and the cruiser world. Always wanted an 80. I finally got one and am amazed at how stout these things are. Anyway... installed a new antenna mast per the instructions in the FAQ and removed the gear strip fromt he old antenna and regreased and assembled the housing. Two issues at play. The antenna doesn't fully retract. It stops with about 8 inches or so still extended. Second issue... the antenna mast housing doesn't seem to extend far enough for the threaded nut to get a purchase on it. Whoever wrecked the antenna before me really buggered up the top of the mast houseing when the old one broke.
Any ideas?
Thanks.
A big MUD Welcome:flipoff2:
Now that's out of the way...
What year is your 80? If it's a 97, the mast will extend automatically to a minimum length when the head unit is set to radio. The length can be adjusted with the dash switch, but you'll always get the extension whenever you use the radio.
If it's not a 97, then things get more complicated. There are two different types of mast drive centers, one that is smooth and one that has bumps on it. The earlier ones had the smooth plastic. If you are trying to put the wrong plastic in a mast assembly that doesn't match it, that could be the problem. If your parts person looked it up correctly by build date, you should be OK unless they made a mistake, but that's something to check.
The plastic end that stick through the fender is pretty important to keeping moisture out, so if you live anywhere that's going to be a problem, especially where it will freeze, you may want to consider getting a new mast assembly. I don't think that comes as a separate part. I'm not sure that has anything to do with the problem you're describing unless it's really buggered up, but it's possible.
Note that the hardest part of R&R the complete mast assembly is threading the coax from the new assembly back through the 90 degree angled opening into the firewall at the top of the fender. Be sure and attach a fish wire to the old coax that you unplug from the head unit so you pull it through as you remove the old one. Even then, it's a bear. :mad:
Use the Search this Forum in the top right corner to pull up some old threads. Lots of info there about this. We'll help you get this fixed. Hang in there.
Are you retracting using the up/down button? Turn the radio on then off and see if it retracts all the way in.
I do have a 97 so I guess that explains the retraction issue. As far as the antenna mast housing goes. No they didn't look it up by date of manufacture. Guess it's a trip back to the dealership. I'm pretty sure it's the correct part as it matches the buggered up weather seal that I removed. I think the motor mount might be bent, causing the whole assembly to sit a little lower than normal. I will order another one as the thought of bending this one back into position doesn't sound like much fun.
At any rate... the amount of information on this forum is amazing. I love it.
Thanks for the warm welcome:cheers:
Norseman,
No problem with the 97 80 series (US models) by date, as they were all the same. It's just that there were transitions in the earlier years. If they gave you the right part for a 97, then you're good as far as that goes.
Like arndog123 sez, turn the radio off (or switch to another source) to retract the antenna. If it doesn't, then you still have a problem. You should recheck things with your install.
On the 97s, perhaps you can use the mast adjust button to bump the motor so that it will go to a different spot or something? On mine, I replaced the whole mast, but afterwards I think if I'd known more, I could have just gotten by with what you're trying to do. I suspect that if you extend your mast all the way, then hook it up, that might work?
I happen to have a good plastic thing-a-ma-jig that goes under the nut on the outside. If that's all you need to make it right, PM me and I'll send you my old one.
Welcome!
For all of your OEM parts I highly recommend CruiserDan. His prices are great even with shipping compared to most dealers. He is an excellent resource and he has an amazing fund of 80 series OEM parts knowledge. (you will find out that most of us only recommend OEM parts, it usually saves $$ in the long run) And don't forget his sidekick Beno, he'll make sure your order is complete and packed nicely for the brown man.;)
CruiserDan at American Toyota, Albuquerque NM, 1-800-432-6668
I believe Menlove also gives a discount to Wasatch Cruisers if are a member of their group.
I also highly recommend Kurt at Cruiser Outfitters. He stocks a lot of accessories like lockers, lift kits, front axle rebuild parts etc. He's a great guy to work with and he's local to you.
Cruiser Outfitters
I found the following pages most helpful when I replaced my mast. All of your questions should be covered here:
Power Antenna Mast Replacement
https://forum.ih8mud.com/80-series-tech/5583-antennae-repair-write-up-pics.html
If the PO did bugger the bracket then either try to bend it back or maybe buy a used motor/bracket off of a parts truck because new ones are over >$100.
If you plan on installing a CB at some point, you can actually get a special splitter (~$30 IIRC) and run your radio off of a CB antenna and can the whole factory setup. That's probably what I would have done if I knew that was possible before I replaced my factory mast.
I'd imagine that most of the Morgan locals use CB so a CB/radio antenna might come in handy:hillbilly:
Look at the link I posted. It's actually not too difficult to tinker with the motor once you pull it partially out of the fender. It will allow you to manipulate the bracket easily.
A new motor is kind of spendy so I'd try to fix the one you have first, especially since it sounds like it's functional. :cheers:
OK... sounds like I need to get back after that motor mount. Correct me if I'm wrong but the chrome nut that slides over the antenna actually screws onto the mast housing thats attached to the motor. Is that correct. If so I may need another solution if I can't get the whole assembly to sit any higher in the fender as there isn't enough of the mast (not the antenna) exposed to screw the nut onto.
-D
D,
The motor assembly includes a long metal extension that comes up from the motor itself. This ends in a sloping metal fixture that has several sharp "teeth" in it. This is sloped to match the slope of the underside of the fender opening. There is a rubber gasket to help seal it further against water intrusion, but it has cutouts for the teeth to contact the metal of underside of the fender, as this is important for grounding to allow the antenna to properly function.
Protruding from the sloping fixture is the threaded metal end of the metal extension. This will be above the fender when you have the motor assembly properly in place. The telescoping metal sections of the mast itself protrude from this.
There are two parts that slide down over the mast. First is a funny looking plastic thing-a-ma-jig Again, it matches the slope of the fender, but goes on top of the fender from the outside. Essentially, it is a washer to seal the opening from the top side.
The last piece is the chrome nut. It slides down the mast and is threaded onto the metal extension that protrudes from the fender from below. It tightens, pushing the plastic thing-a-ma-jig tight against the fender to seal things up.
So, yes, the chrome nut screws onto the mast assembly to help hold it in place. You probably do not want to tighten the (single?) bolt lower down that holds the motor assembly tight against the fender until after you have used the chrome nut to pull the whole assembly UP against the top of the fender. I remember doing this myself, but this is a place where an extra set of hands might come in handy. Only tighten the lower bolt once the chrome nut on top is properly in place.
BTW, you're not missing the plastic thing-a-ma-jig are you? Because if it's not there, then the chrome nut cannot properly hold the whole assembly up in place. There also the possibility it's been broken or otherwise is failing to do what it should. If you're not sure about it, let me know and I can post a pic of a good one.
Mike... thanks for the detailed post. I think I am missing the metal piece that the chrome nut engages on top of the housing as the the top of my housing is nothing but buggered up plastic. Though it looks as if the chrome nut was actually screwed onto it in some fashion. I'm assuming that the threaded metal part on top of the mast housing isn't replaceable. That being said, if I understand you right can adjust the height of the housing by unscrewing at the base near the motor? Or were you refering to the nut that attaches the motor mount to the fender?
Thanks for all the help with this.
FWIW when I purchased my cruiser the antenna (metal housing) was missing and only the plastic part was exposed. However it was snapped off at the end. When I took it to the dealer they told me the antenna wouldnt work properly unless the plastic part of the antenna was replaced because it actually connects to the metal sheath that extends up and down and makes the unit work properly. Was told the only way to replace the plastcic piece was replace the entire assembly. Dont know if this is helpful or relevant. :meh:
D,
The top metal part of the mast assembly protrudes through the bumper. That is what the chrome nut screws down on to. The plastic thing-a-ma-jig, essentially acts as a washer and goes on over the protruding metal threads of the mast assembly. If that's not sticking up high enough, then try loosening up everything below, push the entire thing as high as you can, and try to engage the top of the mast enough then.
If there's nothing to engage and screw it down onto, then maybe someone has mangled the end of the mast so badly -- or the chrome nut so badly -- that it won't tighten. At that point, you either hillbilly a new nut onto it if that's the problem -- or you go for the new (used) mast assembly to get something with good threads on it.
Victory! Just wanted to say thanks to all who responded. Everything is back together and works as advertised. What a great forum.
-D
