Another Suspension Question
Redwood City, CA
Okay, let's see here is a little background on my LC.
Yes I have searched and found threads related to this but not with stock bumpers.
I have a 97 LC. As of now I have all stock bumpers so no weight issues there, but I do have a dual battery install. I have OME 851's in the front with the N73 shock. No castor correction...yet, but I do have the yellow ones sitting in the garage. For the rear I decided to take out my 860's and install some 863J's (laying around in the garage) to check out the difference and of course I liked the difference in height. It also levels out the Chaser trailer without going to a flipped higher hitch. The rake as of now is 23 1/2 in the front and 26 inches in the rear (bottom of hub to flare). I want to do a spacer in the front to level out the truck.
Question: How many other mods will I "HAVE" to do since I've gone up about 2 1/2 inches in the rear and hopefully 2 inches in the front?
Thanks,
Chris
I don't know if your rear OME's came with the longer rear brake hose, our's comes with a 23 in. SS braided hose. It can be ordered as a separate item for 30 bucks.
Don't do a spacer, get a pair of 850Js. Then you're gonna want slee blue bushings or landtank plates and possible a DC shaft. You're gonna want/need the slee blues or the landtank plates if you do a 2" spacer to level it anyways, and you're not gonna save money by buying a spacer vs selling your springs and buying new Js.
X2, then you're going to add the SS longer brake lines and possibly an ARB winch bumper and winch, then the supercharger and then you have to add the bumpstop blocks and so on.......:D
