Another stupid Birf question ?
Walnut Creek, CA Bay Area
I'm about to start a major rebuild on my 93 LC, seperate & detailed rebuild thread coming soon, and this will involve the 'dreaded' birf rebuild.
I thought I read somewhere that the front diff needs to be locked before starting this procedure. I've scoured my pages of 'birf rebuilds' that I've saved & the FSM but I cant find mention of this starting point. Did I imagine it ? :doh:
I do have the diff lock located at the left side of the steering colomn: of course, it's usually in the OFF/horizontal position.
Thanx in advance...
Locking the front is only a recommended step by your fellow 'Mud bretheren. Not all 80's came with F/R lockers. How would they (non-locked) do the rebuild if locking the front was required? ;)
:cheers:
I don't remember for sure but it seems it's the rear axle that needs to be locked when removing the axle shaft. If it's not locked, the locker collar can become misaligned and make reassembly very difficult.
Obviously, if you don't have a locker you don't have a locking collar to worry about.
:cheers:
Yeah, that makes sense ! Like I said, it was a stupid question but I know I read it somewhere ? I just want to make sure I get this damn thing perfect !
Thanx again.....
There are no stupid questions, only inquisitive idiots. Not trying to imply anything, of course. :)
Good luck on the rebuild.
Just FYI I just finished a LHD birf, and my locker motor is presently FUBARed, so the diff had to remain "open".
If you are careful about removing and replacing the front inner shaft, you shouldn't have a problem.
Just finished my rebuild. I did not lock the diff although I could have. Had no problem getting the axles back in. Do pay attention to flat areas on birf. Flats have to be at top and bottom.
From the FAQ:
"Note:lots of folks recommend having the front diff locked if you have that option before removing the axle. makes it easier to re-install"
