I've been wanting to build some drawers for my rear cargo area but haven't had the time to build something top notch like a lot of you guys have. I knocked this out in an afternoon and am real happy with it so far. I removed my rear seats since they are never used and wanted to make it so I could use it as a sleeping area too. I carry all my gear in a sea bag which tucks in there nicely with room for other goodies, camping gear, etc. Hi-Lift, ax, and shovel will be mounted on the inside rails. It will also keep things out of view of car clouters. I plan on adding some tie downs on the corners as well as getting some beefier latches. I can add drawers to it someday if I like. The front is bolted down to the existing seat bolt holes. I glued the foam mat to the plywood and trimmed off with aluminum edging. The bed just tilts up for access as the front of it is hinged. Cost about $50 as most of the stuff I had on hand.
Thanks to MUD for the motivation!
