Another Storage Box Thread
Colorado
I just picked up a '93 LC last month and am starting the mods on it to make it the next family adventure vehicle. This weekend I integrated a storage box that I originally built for the back of my TJ. It's made of 1/2" baltic birch plywood that is dovetailed, glued and screwed together. I'm a big fan of not having things flying around the cab in the off chance we roll it, either at low or high speeds, as there will be kids in the second row. To mount this box, I started by building a support frame that ties into the third row seat attachment pionts. Basically I used the U-Clamp portion from some wire cable connectors whose radius matched the diameter of the seat attachment points.
Once this frame is securely attached to the floor, my wooden box is then set on top of it and there are several 1/4 inch bolts that suck the box onto the frame using spike Tee nuts. These bolts/nuts only really help locate the box and provide a little bit of extra security. The real security to keeping the box from flying around the cab is this cage that ties into the floor support on both sides toward the back and at two points in the front. Furthermore, I used spike Tee nuts and bolts around the perimeter of the frame to tie it into the box.
Everything gets tightened up and there is zero movement of the box within it's frame/cage.
O.K. The real reason for this box is to corral and sequester unruly kids on long trips.:)
I topped the box with a Catch-All cargo mat that was originally for the back of my jeep and some tie down points that use spike Tee nuts through the plywood. I also mounted my version of a Power Tank ($52 Co2 fire extinguisher with a $45 150 PSI Valve that works awesome) and a real fire extinguisher which are bolted to the metal frame and wooden box.
Now I have plenty of secure storage for my tools and recovery equipment. What doesn't go in the box can be tied to the top or placed along side of it (something light like sleeping bags).
Adam
that box isnt going anywhere, nice job!! I'd put some vent holes in for kids though, wait, scratch that, make it sliding vents, you'd still be able to hear the kids through the holes.
