Another running board question: pics
MA
I am in the process of mounting some great new running boards I got from City Racer. I'm a bit confused about how the perch mounts to them. As seen in the photos, the perches already have rubber bumpers mounted on them. However, in that spot the running board has a welded nut for a bolt to screw in and tighten down the running board. The way the rubber mount is on the perch rather negates the use of this welded nut. That is, unless I take out the carriage bolt from the perch end and replace it with a hex bolt and run it through the perch and rubber from the bottom and up into the welded bolt on the running board. What gives? How were these originally mounted?
I'm with you, my guess is remove original setup, keep rubber pads, and install new bolt from the bottom side? Others will chime in....
Original mount is different and allows the top of the carriage bolt to slide in a wide groove and then set into a smaller groove holding it in place.....google a few images and you'll see
Original mount is different and allows the top of the carriage bolt to slide in a wide groove and the set into a small groove holding it in place.....google a few images and you'll see
X2.
Removed the carriage bolt and use a bolt from the bottom with the pad in between.
Got it. Thanks, guys. I can certainly do that. I was wondering the reason behind the two items not quite working together as is. Now I know the reason: the running board is not original on the bottom. My truck is all chewed up in this area anyhow, with diamond plate over the rockers so a little modification/not-stock is not an issue.
