ANOTHER rear sill question
Cary, NC
Well, I think I have read every thread that has "rear sill" in it, and I still have a question....
How are the rear quarters attached to the rear sill member? Are they spot welded? Can the sill be removed w/o cutting too much of the quarters? I don't have that much rust in the skins and don't want to do any more sheet metal fab than I absolutely have to. Let me know if pics would help render an opinion.
Ramon Weller
They are not attached to the sill as far as I know. I didnt weld my sill to the rear quarters. My reasoning is that the rear of the frame will torque independently of the body. If you weld the sill to the quarters you could get body damage from it shifting around.
Yes...that is the rear sill member I am referring to. The sill is shot below ambulance doors and has rusted from the inside out through the passenger side quarter - just like everyone else's has. The rust, however, stops before the radius starts for the quarters, so I am hoping to salvage that sheet metal and not have to replace it.
Sooooo, the real question is can the rear sill be removed w/o chopping the quarterpanel sheet metal?
Pinion - I can tell the spare tire carrier bolts through the sill and quarter, so I know it isn't a "floating" configuration. I am just wondering if there are spot welds b/w the rear sill and the rear quarters that will have to be drilled out.
Thanks guys!
Ramon Weller
Oh, no there arent any. If you want to save some cash, go get some 2 1/2 x 2 1/2 box and put it in there to replace the sill. Stronger and it wont rot as it doesnt act as a salt/sand catcher.
Yes, the rear sill is welded to the quarters, and to the inner fender. There is a vertical weld at either end of the sill on the plane with the back doors, and a horizontal weld to the inner fender or brace. It's more extensive on the 79 and later, there's a tie piece that's curved which welds to the inner fender and top of the sill, and it's still welded vertically at either end. If you want to do a cheap and dirty, just cut the sill out where the rust ends and weld it there.
The quarters are spot welded to the inner fender brace, if it hasn't already rusted out. This is the brace your spare tire carrier bolts through.
