My radiator decided to start leaking a couple of weeks ago and could not determine where it was coming from untill this morning when the whole got a tad bigger. You can't see it in the pic but you can see that the coolant has been leaking for a while because at the top where the rim is, it is discolored from the hot coolant seeping through. I decided to take it out and replace it again.....the last time it got done was back in 04'. The radiator was caked with mud which you could see in the pic but I am not sure if that was the determining factor for a this radiator to start to go bad because it just seems cheap! I was quoted $580 thru Napa and got it for $180 thru 1800radiator. any suggestions....?
I did some research on the forum and found that the 93-94 is the most recommened radiator for 95 and up but what about the 91-92 what is everyones take on that. I am not sure if it is different on the 92 which is what I have and if it is will it work....? I am changing all hoses (upper and lowers and the stubby in the background that is pain to get out) and belts.
thanks everyone!
;p
thanks everyone!
;p
