Another Power Steering Question
Edmond, OK
I have done a search and can't seem to find my answer. A recent large PS leak led me to think that my HP line was leaking (it ended up being a crack in a low pressure line!). After replacing this and the low pressure lines I am having a problem with air in the lines. I have the front end on jack stands so bleeding the system was easy. I even flushed the entire system thoroughly. After running the engine for 5 minutes after I shut her off the system has the typical bubbly fluid coming out from under the closed PS Reservoir cap. Could this be as simple as needing a new cap (hence seal?). I have one on the way but for now I am stumped. There doesn't appear to be any leaks I can see in the parts I replaced. Any help would be appreciated. My Cruiser is a 94 FZJ80 with 102K on the clock. New to me but it's been hibernating in my garage while I fix this (the minus 20-30 degree temps here in Minot don't help the wrenching efforts!). Thanks in advance guys. I have been a lurker here for years. I love this site and landcruisers. The addiction began 12 yrs ago with a 82 FJ60, then came the 62, then the 92 FJ80 then a 98 100 series and now I am back to the oldie but goodie.
Cheers,
Grand
I had the same issue and thought it was the cap, but I re-bled and it worked out, no new cap needed. The most important issue with bleeding is to take your time - wait for the bubbles to clear completely. Here is something I sent to another user who was having this issue:
_____________________________
- DON'T start the engine until you have bled the system... to bleed, do this: fill the system to proper capacity, jack up the front end, slowly turn wheel from lock to lock about 10 times. Watch the fluid level to make sure you don't suck in more air. Put the lid back on lightly and let it sit for an hour or so. Repeat this process like 3 times. Have a friend watch and once you get to the point where there are no air bubbles coming up in the reservoir and the fluid level remains constant, you can be pretty sure you've bled it properly. It should be OK to drop it and start the engine now. Turn the wheel lock to lock a couple times and listen for moaning.
So I realize this thread is extremely old, But, when youve got it on jack stands and your rotating the wheel is this done with the key on, engine off? I too am a bit of a noob and just want to clarify before i blow something up.
The key will have to be turned far enough to disengage the wheel lock. The vehicle stays off during the process.
