Another power steering flush thread
Ione CA
It was seriously time to do this , That fluid had some stank!
I kinda went at this from the joe duma$$ angle.
First off I disconnected the lowest low pressure hose and let drain.
Second I plugged the low pressure on the resivior side.
Third I taped off the fill opening and inserted a regulated air supply.
I used a ball inflator to pierce the seal (tape) and regulated to about 25#.
It all came out , well about 95%.
This is not the cleanest method, but could be made more sano with some tweeks.
ken
Just an update on this:
Im very satisified with the fluid exchange , Its still clean that tells me most of the fluid was removed.
One note : after the flush and fill I did not raise the front end and cycle the steering , I should have.
On the test drive the steering wheel at speed (and turning) would vibrate.
The system was bleeding it self out.
Now with the system blead the steering is very smooth and solid. :)
ken
