Another victim... My '97 has 175k miles and I finally fell Vic to the PHH failure. I took the family camping in WV last weekend and ran pretty hot through the hills which I'm sure sealed its fate. Ran 200-218 most of the way according to the ultra gauge. Fast forward a few days...I came out of work on Thursday and found all the coolant on the pavement. Thank god it didn't give up during the trip. I dumped in a gallon of distilled and limped home. Fortunately I already had a samco silicone PHH replacement and thermostat on hand. Picked up two gallons of toyota red on Friday morning and went to work. I followed the "painless PHH replacement" thread by zipastro and it took me about an hour to swap the PHH... I was shocked. I was surprised to find the lower tube bracket without a bolt (maybe it had been replaced once already?) so that definitely saved me a little time. Overall, with the PHH, thermostat, coolant flush, and resetting the PS wheel bearing preload, it was about 4 hours. Here are a couple of pics from the camping trip and the PHH split...
So I've noticed my temps are still around 195 around town since swapping the coolant and thermostat. Id like to get those temps lower so I'm going to change the fluid in the fan clutch shortly.
Also, I wanted to pass on a potential jackass moment during the coolant flush... I had bought a Peak coolant flush kit but I got frustrated trying to find a suitable place to plug that thing in to do the flush. I also didn't plan well and didn't have any pvc or extra garden hose so here's what I did. I left the block drain plug and radiator petcock out, uncapped the radiator fill neck and put the end of the hose directly into that. It actually sealed pretty well and blasted water out of the petcock and about four feet out of the block drain. I did that for about three minutes until the water was clear. Sealed it all up, added distilled and ran until hot, drained again then added coolant and topped off with distilled. Does anybody think that jankey hose-in-radiator technique could be harmful?
Point is, thanks to zipastro and others for the awesome PHH write-ups. This job is nowhere near as intimidating as some make it seem. Just do it!
