Another Painless Harness Help
Orlando, FL
Hey all,
I'm trying to connect the painless harness to the GM style switch without using a dimmer switch.
It's been pretty plug-n-play up to this point but this seems to have me confused. Painless tech support isn't horrible but also not helpful. I could use some help.
I"ve hooked up to the GM switch as per the diagrams but am left with the tan, green and 2 blue/yel wires that hook up to the dimmer. how are these hooked up to bypass the dimmer?
Thanks,
You're not going to run a dimmer?
There's a wire coming out from the switch that goes to the dimmer and then two wires come out of the dimmer switch - one to high beam, one to low beam. If you are bypassing the dimmer, just hook the wire running to the dimmer directly to the either the high beam or low beam wire - whichever one you're going to use.
I should add I assumed in that answer that your harness assumed a traditional position for the dimmer switch and was not expecting a stalk mounted switch. Although I assume it works the say either way.
