After putting up with a spongy 80 for 6 months I finally sold a gun and got an OME kit. I went with the Medium kit because I am running out of guns to sell and don’t expect to add a bumper for a while. This truck has 124k on it and the suspension is hurting.
Here is my experience.
I installed the Steering Stabilizer on Thursday PM. The best part about the install was my 16 month old son’s help.
The install went easy thanks to two weeks and two cans of PB Blaster. I bought a tie rod end tool at the local tool store for $16. It worked great.
The lift install started at 4:30 on Friday. It would have begun a little earlier but I was out of beer. Due to the POS Sears 3 ton floor jack struggling I jacked the truck up in two stages. First under the pumpkin to get the PS up on the Jack Stand. Then under the DS LCA to get the DS up high enough. Everything came apart relatively easy considering the East coast crud. Again PB Blaster is the bomb, usually.(more later) The DS shock bolt was a piece of cake with the BFW and a 17mm box end. Once I got the nut started I was able to spin the body with my hand. The PS was a little more stubborn so I figured out how to lock the BFW in place and get two hands on the top with a breaker bar.
In order to get the shock out I had to use a BFH to get the lower shock pin loose.
The photos show why.
At this point I had left the BFW on the shock and hit the bottom pin with the BFH. Of course the BFW fell off and landed on my digital camera cracking the display. I figured that was a sign I needed to step back and drink a beer.
The spring install was a piece of cake. Just followed Slees instructions without a hitch. “A” spring on the PS and “B” on the driver side. Just for kicks I did the comparison method also.
The photo shows the springs and the taller ones are obviously slightly taller. So yes you can just match the springs if you can’t remember A vs B.
The highlight of the front install was my sons help. I was laying under the truck and needed an ½” extension @ 24” past my reach. My 16 mo old was supervising my work and when I asked for “that shiny thing” he grabbed a screwdriver next to the extension. “No the other shiny thing” and he grabbed the extension and handed it to me!
Total time, including beer breaks, two hours.
The rear install was a little more of a pain. The sway bar mount bolts were a pain. One bolt on each side broke. The photo shows the bolts and the East coast crud that helped them to break.
This is one place the PB Blaster failed to help. You need to get the Blaster into the frame on the bolts to do any good. Even then I am not sure it would help in this case.
I unbolted the ebrake bracket as well as the brake line bracket. At close to full drop the ebrake line was very “stretched.” Again thanks to the PB Blaster the bottom shock bolt came off surprisingly easy. I chased the threads with a 12x1.25 tap just to clean them up. I replaced the bolts with new ones from the factory.
The upper shock mount bolts were nothing short of scary. They had enough crud on them that I was sure one or more were going to break. I alternated backing them out letting each cool off. I eventually got them off but sweated them the whole way out. The upper shock mounts were really cruddy and took some persuasion to get off.
I had noticed that the truck was really mushy on the road. I had guessed that the PS front shock was blown. After getting all the shocks out the DS rear shock was the culprit. It was flat out dead. I could compress and extend it without effort. Reassembly went as per the Slee instructions.
Over all this was a very easy install. If it weren’t for the broken bolts I would have given it 1 ½
Now the best part. It drives better than a new truck! I drove it up to a rough FS road and hit some big pot holes at speed. I heard them but hardly felt them! Hoorah!
After clean up, a bowl of Elk chili and a couple of beers I am very happy with myself and my truck.
ps Before and after photos tomorrow when it is light.
.Now the best part. It drives better than a new truck! I drove it up to a rough FS road and hit some big pot holes at speed. I heard them but hardly felt them! Hoorah!
