Another loose hose...need help
East TN
I discovered a loose/disconnected hose. Did some reading and from what I gather, it should be going to the dizzy to provide clean air from inside the cabin.
Well, the two ports on top of the dizzy are connected to something already. I'm guessing one of these are wrong.
Here is the disconnected hose believed to go to the dizzy...
First dizzy connection going to a 'T' that goes thru a valve up to the air cleaner. From what I've read, this seems right...
Second dizzy connection goes straight up and connects underneath the air cleaner. This one I'm not sure about...
Can someone confirm or compare to yours?
Thanks!
BAM! Thanks for the pics D. I spotted it at first glimpse.
It feels good to know when things are hooked up correctly. Feels even better when it improves performance. But my luck is usually....get it hooked up right and get no noticable results. Oh well, still nice to know it's right.
I'll be taking care of it after work. I'll post up if this leads me to another loose hose or if she runs like a scalded dog!
The connection at the PCV valve was blocked with a screw. (You can see it in the second pic, left hand side.) Instead of running to the PCV, the hose was going straight to the dizzy. The clean air hose from inside cab was just 'hangin' out'. Not sure how I haven't noticed it til now.
Removed the screw and connected hoses properly.
On to the next one...
