Another Linkage ?
Western, MT
I have a 3spd transfer mounted to a 4spd tranny... have the longer actuator rod installed, 4spd shift lever, but need to complete the linkage...how have you done it? As always, pics would help...
Also, what position does the lever on the top of the transfer have to be in? I think there are three clicks :confused: Does it have to be toward the front, back, or in the middle? Didn't look before removal, and yes have moved it quite a bit in the process :whoops:
I have done searches, but nothing came directly for these questions.
Help would be appreciated.
Thanks, again.
Thanks, again.
Think the easiest would be to get a 4spd tcase shift lever and pivot, and be done with it, provided it is a Toyota 4spd tranny....
Lever on the top if the tcase-
Forward is high range
Middle is neutral
Rear is low range
Good luck!
-Steve
I do have the toy 4 spd, and the 4 spd lever and pivot, but the linkage is too short...lengthen to make it work, or is there some pivot point in between as with the old 3spd transfer linkage?
Four speeds did not have that bell crank affair, IIRC on the tcase acctuation linkage...
Lengthen your rod, and you should be good to go.
Good luck!
-Steve
