Another lift question
Sacramento, CA
For a 96 LX450, all stock as of now. I'd like to run 255/85-16's for now, with the option to maybe throw on some 315's in the future for a few tougher trails. That being said, the 255's will be the primary tires and I'd prefer the lowest possible lift to maintain handling and stability.
Adjunct questions:
Will the OME 861/862 springs give enough lift for the above goals? And with these springs, is any caster correction required?
Anybody have experience with the MAF 3-inch kit with the front drop brackets? I'd rather not deal with installing the OME bushings. Will the 255/85's look ridiculous under a 3-inch lift?
Thanks!
You can run the 255s with the stock suspension. Some people have needed caster correction with the OME stock-height replacement suspension, but others have gotten by without it. It might be a matter of how much weight you have on the springs. Looking ridiculous is a matter of opinion.
the 255's are basically a 33" tire right? They will fit.
I just ordered Slee's 4" Do-it-yourself lift kit today. They claim you can run a 35" tire on that size lift.
They also said they are back ordered, so I have to wait 2 weeks till I do the lift. Grrr.
I plan on running 35"'s or the metric equivalent, which is about a 34.5", 315/75-16...
You can easily run 315's on the OME Medium lift. Heck, there are people that are running 315's stock, you just don't get much flex.
Slees 4" will fit 35's easily. Now 255's are no where near 33" on my Tacoma I have 265's and they are under 31". so 255's are closer to 30".
Both numbers are required to know the height of a metric sized tire.
The first number 255, 265, etc is the approximate section width in millimeters. The second number is the height of the sidewall expressed as a percentage of the section width.
Your 265/70R16 has an approximate section width of 265mm/25.4mm per inch =10.43" Let's call it 10.5"
The height of a sidewall is 70% of 10.43" = 7.3"
So two sidewalls @ 7.3" = 14.6"
Add that to your rim diameter of 16" to get 30.6", which we will call 31".
So your 265/75R16 is a 31x10.50.
Applying the same math to 255/85R16, we have a 33x10.00
Thanks for the feedback. Right now I'm leaning towards the 3-inch kit from man-a-fre due mostly to ease of installation. Anyone have positive or negative experience with the caster control brackets used in this kit? I'm typing on an iPod now and can't figure out how to cut and paste a URL, but the drop brackets are made by 4plus.
Thanks!
I got around 1" to 1.25" lift with the OME 861/862's, and knowing some people run 315's on stock suspensions that will provide a little more room, but most likely limiting your articulation in more extreme terrain.
I haven't corrected the caster yet, but there could be some improvement as my caster is right about 1 degree with the 861/862's and spec is 2-4 degrees. Every truck is different...
I run 285's and have had no problems with the 861/862 combo.
255/85R16 tires on the factory rims will fit at stock height with NO rubbing at all. Believe me, I've tried.
These are on tundra rims, stock height. I swapped them onto factory LC rims and still no rubbing.
Great tire BTW. I've been running these forever.
