(another) Idling issue thread
Southeastern NM
Thanks to this forum and the parts of the FSM I managed to decipher, I now have only one warning light remaining on my instrument panel...
...Airbag error code 31, Airbag sensor. I searched previous posts and the FSM, Think I can kick this one in the butt on my own (As long as I can get a new sensor module for next to nothing, just in case that really is the problem)
Heres the new problem-
when I went to take it for a spin tonight, I noticed It was idling "differently" than it did yesterday... unsteadily. Not super bad by any means, but just enough for me to take notice... and the exhaust smells very strong, not like coolant, but it has a very strong exhaust ododr I didn't notice before. If I can capture it properly, I'll film it idling and post it up for your expert opinions tomorrow.
Ready for it?
here we go... :deadhorse:
WHAT COULD BE CAUSING THE UNSTABLE IDLING?
x2 on the air hose. They are brittle and prone to breaking on older trucks.
Second thoughts are the usual tune up items. Injectors, plugs, wires, rotor and cap. If you truck sat for a while, could be some old gas too. Run a tank of new gas, some injector cleaner and see if that helps.
Daisy
The air hose was broken cleanly into two separate pieces, must've happened when I had it serviced the other day.
I'm not sure how much an OEM replacement would cost, but I used a CBOA hose and a piece of the original (as a homemade adapter) and it runs beautifully now, but its ugly as all get out.
May want to check your wiring harness near the brace under the glove box. There have been some that rubbed the insulation off of the ecu wiring, causing a slight and intermittent miss.
