another idle problem....I think..
DEN
The day after returning from a long full day trip, which my 40 ran fine (smooth idle, good acceleration), it now idles erratically. I usually pull the choke all the way out, turn the key, the motor starts and then I let it idle for a minute or so with the choke out.
Now when I am letting it idle fast it hesitates, or sounds like it is missing or something. I am not an auto expert but I replaced the fuel filter, cleaned the air filter and sprayed the carb with carb cleaner. I also changed the spark plugs but it is still the same.
When I push the choke in though, the idle is the same as it used to be. The motor does not stall when I am driving, but until I have the accelerator pushed down steadily (right before shifting to next gear) the motor misses and sputters like it does when the choke is pulled out at idle.
I can drive it, and once I get past the misses and/or hesitations the acceleration feels strong and the ride is okay.
I have a 2f, stock rebuilt carb, stock distributor
Thanks
Pull the topcover of the carb and clean the junk out of the jets and the bottom of the float bowl.
top cover?? Does that mean pull off air cleaner and spray carb cleaner in the carb?
Thanks
No.
It is taking the top cover of the carb off.....this is deeper than the air cleaner...
It sounds to me like you have dirt in the fuel metering passages....spraying carb cleaner into the carb throat will not do anything....
