another "help me pick suspension" thread
thanks a ton guys. Will I need coil spacers as well as the 862 for my setup do you think? Or just the spring?
The 862 plus 40mm gave me 1.5" of lift.
I don't think you need that much lift.
Picked up my 862s today! Planning to install tonight.
Can anyone point me in the direction or explain the easiest way to swap rear springs? I looked at the Slee instructions but they look like way overkill as they're for full front and rear springs AND shocks.
Not sure whether I'll need to remove rear shocks and swaybar endlinks.
Any help would be much appreciated.
Edit: Maybe I'll just do this :rofl:
Super easy!
1. Unbolt your sway bar and shock
2. Jack up the rear with some wood blocks
3. Jack up the axle and take off the wheel
4. Lower the axle till the spring pops out then pop in the new one
If you have any issues getting the axle low enough to pop out the spring then all you need to do is use the bottle jack between the axle and frame. Factory springs should pop out with ease though.
So these thread pop out all the time because I don't think we have a good reference table of some kind to definitely help with such selection because everything is based on personal configuration. I think we should started a new FAQ thread with a better way of selecting the correct spring for the job aka weight. The key here isn't I have a RTT and have 15 gallons of water, I myself was surprised to find out my rig weight per axle at the truck stop. I think we should have a table for reference based on actual weight per axle and the spring rating best matched for application.
I am going on my third set of springs(4th counting the original) and I am still struggling with spring selection.
Super easy!
Awesome thank you. Couple of questions:
Can you clarify jacking the rear up? Just jack up the axle by the pumpkin then put stands under the frame rails?
Also do you just unbolt the bottom of the shock?
Jacking up the rear meaning using a floor jack and some wood blocks and lift the body by the frame. Then jack the axle up so you can take off the wheel and then let it drop. So you do need 2 floor jacks or 1 floor jack and one very tall jackstand.
You can however try that method without taking the wheel off because the stock springs are fairly short. So a 4x6 block and a high floor jack should be able to pop the spring out.
Thanks everyone for your help. Got the 862s in there last night with some help from a buddy. I only have one pic so far, but it definitely lifted up the rear to the point where I have a little bit of a stinkbug even with the tent and rack. I'm really happy with the stance for now and it should handle the weight of a weekend trip.
Now I just need to modify the spare tire mount
