Another fan clutch problem.
Burlington NC
I just had to replace my radiator because a rock hit a fan blade while i was crossing a creek, and it sent the rock through the radiator...
Now the fan itself is loose. It doesnt turn smooth and causes the truck to overheat.:frown:
Am i going to need to buy a fan clutch?:doh::confused:
Any help is appreciated
Are you sure it's not the fan itself that is damaged and out of balance?
Either way, I'd replace the fan clutch on a 10+ year old truck, especially while the radiator was out. Or is it back in again? Still, the fan clutch isn't that hard to check, and I'd get both clutch and fan new if it had any potential for cracks/damage. Not that much $ from CruiserDan. Get the blue base clutch, and if you're in hot weather climes, try the fluid mod.
i actually think it is the fan itself.
The Fan Clutch seems to be sturdy and working properly, its the fan blades, there loose and wobble instead of spinning smoothly.
is there any way to tighten the fan down? IT seems as it is just loose.
Technically, yes, if it's just loose you could tighten it. But you need to remove it first. 4 nuts need to be removed to get the clutch loose, then fan and clutch assembly can be removed together. I think there's some really good instructions on how posted here that a search would bring up. I'd suggest removing and inspecting, then decide if it indeed came loose or is broken/damaged in any way. Might be able to pick up a used one here too from someone local-ish.
ok, i know exactly what 4 nuts your talking about.
Tomorrow i'll take it out and post some pics up..
College life isnt the "richest", so i'm hoping its just loose
finally an update, it was the fan clutch.. so i had to replace the radiator and the fan clutch..
but i picked a cheap one up from advanced...
