Another electrical problem
My 1995 land cruiser has electrical gremlins. When I open the lift gate sometimes the lights turn on. Sometimes the dash buzzer sounds. The rear dome light is on but dim unless I have a rear door open in which case no symptoms present themselves. Also on occasion the air conditioner will keep running without the key in the ignition. I'm assuming I have a grounding problem somewhere. Anyone have any advice where to start and what to meter? Also, if I disconnect this plug in the driver side rear quarter behinds the jack then the buzzer stops and the light turns out. I'm assuming it is the harness going to the lift gate.
