Another Driver's window no operate thread - SOLVED
my switch went bad, I tried and tried to repair it, I believe the "auto down" function was wore out? in mine and was not allowing the switch to function correctly.
I bought an ebay "tested 100 percent aok switch", which was worse than mine, what a load of crap.
So I then bought a switch doctor replacement, works great but its a total redesign and cant do the auto up mod on it [too chicken**** to tear it apart to see if its doable until I have a new oem in place to replace it]
I'm going to dig in to this more tonight when I get home from work. Had to leave my 80 at home today because the window is stuck part way down. First time my 80 has ever left me stranded in 23 years.
Should have done the "Garbage Bag" mod........:flipoff2:
If it had happened on the way to work I would've done it when I got there! I have heavy duty contractor garbage bags and duct tape in my 80 at all times.
I just have to figure out how to bypass the switch right now to test the motor. Electrical is not my thing.
Yep. It's the motor. Damnit.
Is there a way to put the window up without the motor?
Yes, you can disconnect the motor from the window regulator while someone is holding the window from falling down in the door. Once the motor is disconnected, pull the window up to the top and either tape it or hold it up while you reconnect the motor to the regulator. It's a pain in the butt to do because the three screws (torx) that hold the motor to the regulator are difficult to reach with the regulator in the door. If you can't get to the screws the regulator will have to be removed, and the glass will have to be disconnected before you can get it out of the door.
the bar that holds the glass at the bottom will come off the regulator assembly with 2 10mm bolts, at that point you could probably slide it up tight and wedge a piece of 2x4 cut to fit to hold it up till you get the new regulator assembly
Window switch ordered from Switch Doctor. Window rolls up when I give power direct from battery (and proper ground).
