Another Disc Question
South Texas
I know this has all been covered but I need info on the parts I need. I've look at different post on this Board but can't seem to find out what parts I need. I have a 72 fj40 and plan on using an 83 mini truck axle as a doner. I think I need the knuckles from the mini, wheel bearings for the mini, wheel bearing seals from the mini, tie rod end and tie rod from the mini. I think the only thing I need from the fj40 is the axle seals or oil seal retainer. I've read that a few people had problems fiting the tie rod from the mini, what depends on this, or what will I need to buy. I also plan on using the rotors and calipars the mini has. Please don't post any axles that you have and want to sell since I already have one and plan on using, I would like my question to be answered. Thanks for the help.
basically, what you want to do is use everything from the knuckles out on the mini. i don't think the pickup tie rod is the correct size for the cruiser. i used a 77 tie rod iirc. get a knuckle seal and bearing kit for a 76+ cruiser/mini.
" Please don't post any axles that you have and want to sell since I already have one and plan on using, I would like my question to be answered. "
this is weak man...
If you stay with the Land Cruiser tie rod you are going to need to use a spacer in the mini arm where the tie rod attaches, as the mini tie rod ends are larger than the 40 series. This info can be found in the FAQ section. If it is your intention to use mini ends, then you will not need these spacers.
The inner axle seals are the same between mini and Land Cruiser. The knuckle wipers/felts and gaskets from a disck brake Land Cruiser and a mini are the same, as are the spindle, wheel bearings and seals from 1979 on. The spindle and lock outs were different on the pre-1979 Land Cruisers that had disc brakes, as were the steering arms/knuckle studs, they are 11 and not 12mm, and have a smaller bolt pattern.
Good luck!
-Steve
