Another Die Hard Group 65 install
6005 ft. Smoky Mtns. Idaho
The Odyssey battery which has been, and is still doing fine for the last three years, didn't quite have the cranking amps the cruiser needs, so I got a Die Hard P-2 Group 65, which fits without stuffing the battery tray, and satisfies the Toyota cranking amps spec. Thats a home fabbed angle iron hold down clamp in the pic. Careful to provide clearance from the clamp, to clear the terminals (so you don't short out), as the Sears batteries don't have the correct post orientation option for the cruiser, so for $100 less than Odyssey, you have to "spin" the battery 180 deg., which leaves the posts forward, and close to the hold down clamp. Some people make new longer battery cables, but I decided to use the stock setup so, I detached the cable behind the battery tray, where it is taped to a bracket bolted to the fender well, to aquire enough slack to reach the new post position. Temporarily remove the rubber grommet from the tray (if you still have yours) that the cable comes thru, so that you can pull the fusible link box thru the battery tray, then reinstall the grommet. I fabbed a 1 1/4" thick spacer from plywood, the size of the bottom of the battery, and attached metal corners to the wood, so the battery would sit in it at the desired height. It's hard to see in the pic, bcuz the battery has a projecting lip on the bottom, for a different type of hold down. Everything is buttoned up now, and the cables are fine without their previous attachment to the fender well. I can hear the starter spin up at a noticeably higher RPM now.
How did you get your wires to stretch that far? I got the 34 platinum and my wires are almost stretched to the max.
Edit. I also moved the fusible link and loosened all the tie down spots on the wires and mine are still not happy. Heck my battery even has the post in the middle compared to yours being smack on the front.
It sounds like your particular rig just doesn't have enough slack. In that case, you may be a candidate for custom cables (or cable extensions) which my local Napa store makes. There are also "high performance" custom cable manufacturers online. Searching this forum may produce results.
