Another center differential question
Seattle
I have been watching videos and reading about different PM's for my '93 cruiser, and some of them make references to the center differential, whether it should be locked or unlocked, etc. Mine is AWD and has front and rear locking differentials, but there is no center diff switch. Can someone please explain this to me? I guess I am just confused about the whole thing in general. Thanks in advance :)
Okay, so when in high range, the center diff is unlocked? Is this correct? Thanks
I found the information on differentials in the FAQ's and am reading right now
Yep. You can add a switch to lock it in high, and you can do the pin-7 mod to gain the ability to unlock it in low, if you want.
Good to know! I appreciate the help. Now, if a procedure calls for it to be locked, do I just need to put it in low, or do I also need to drive it and make a turn or two in order for it to lock in?
It, and any locker, will engage when there is wheel slip or speed differential. You don't need it to actually lock before you get into a tricky spot.
