another CEL thread
SO. OREGON
I'm chasing a CEL gremlin. I knew I kinda smashed up the O2 sensor changing exhaust gaskets so today I put in a fresh one. Tried resetting with ecu fuse. Didn't work. So I disconnected the negative battery term for an hour or so while I was doing stuff with my son. Reconnected and still was showing up so I pulled the code again. O2 sensor and lean air. Pulled the 02 again and made sure all connections were tight. Did the ecu fuse, still same 2 codes. Pulled the negative for about another 20 minutes. Reconnected it, CEL still on, idling at around 2000 rpms. Im still not sure if these have to "relearn" so I went and did some honey dos with it so I could cycle it about 10-12 times. Came home and pulled 4 codes now?
O2 sensor, lean AFM, 2nd O2 and rich AFM... Wtf haha. 3FE BTW.
