Another CDL question
Salt Lake City, UT
OK, I scoured the innerwebs for this answer but I came up short. Looking here to fill in the gaps. Thanks in advance.
Looking to install the CDL switch but not looking to pay $45 at slee for the same thing that $2 at Radio Shack will accomplish. What two wires on the harness plug do I switch? I tried to unplug the terminator to see if that makes the CDL kick in, but no such luck.
And then the pin 7 mod, I know how, but I find the why a bit puzzling. What does the pin 7 mod give me that the CDL switch does not already provide?
Why not just pick up a used hazard switch? Many different models of vehicles use the same sized switch.
Pin 7 allows for the CDL to be unlocked in low range. ABS is turned off whenever the the CDL is locked.
One thing to know/remember about the ABS: If you engage CDL at speed, say 10 mph (not sure of exact speed) or more, ABS will stay deactivated (light stays on), even when CDL is disengaged, until you shut ignition off. Then if CDL is still off, ABS will reset and be activated (ABS light goes out) again when you start engine.
Done. Now what two wires do I terminate to the switch? I tried to break the terminator wire but that did not kick to CDL in. Thanks.
Why not just plug it in to the wiring harness?
OK, there seems to be a slight disconnect here. Apologies for not being more clear. Sorry.
  • A hazard switch has two leads on it.
  • The harness has 4 or 5, plus the terminator plug
  • The harness plug will not plug into the back of the hazard switch
I'm just trying to figure out which wire on the harness to run through the switch.
Slight might be too slight a description. :p
So you picked up a hazard switch, yes? It does indeed plug directly into the pigtail that is located in the dash behind the existing buttons. You will likely need to relocate a button off the top row to the bottom.
I'm not following why you're trying to hack something that is plug and play.
/me edits
This might help?
http://www.lcool.org/technical/80_series/abs.html
Done. Now that we got all of these unpleasantness out of the way...
It's just that I had to cut a tab off of the CDL plug to make everything fit. Thanks for holding my hand through this.
-M
