...Another Audio System Install w/ Pics
SF Bay Area
Ok, so like many I soon discovered that while the LC talked the talk and walked the walk in the 4x4 department, it left something to be desired in the audio department. I had set up my last vehicle with a decent sound system, so I decided to do the same with the cruiser. I am not very picture happy, so these are mostly afterthought photos taken either on a crappy camera or crappy camera phone lol -
The plan - replace stock head unit, remove/replace all stock speakers, unplug both stock amps and rear woofer. Here is the stuff going in:
Left to right: 5.25" Alpine Type S Coaxials, Phoenix Gold 6.5" RSd components, 10" RE SE Sub.
More pics, this time with both amps (Crossfire VR1000D mono and Crossfire VR300 dual channel). Head unit is an Alpine 9833, an oldie but goodie (from the era when head units were built to last). Has 2 sets of 4v preamp outputs, 4 channel 26 watt RMS amp, full crossover (2way or 3 way), sub output, AI-net for ipod, 5 band equalizer, other goodies I don't really recall. No pics, but I installed this + the little pocket underneith to hold ipod connect/ipod/etc
Here is the left side of the car torn up. I ran basically everything except the speaker wires through the left side of the car (1 run of 4ga power wire, 1 run of 8ga power wire, two RCAs, remote wires). It all fit nicely right alongside the stock wiring. I think I cut 1" hole in the carpet, which I didn't even end up using.
In the rear, I put the Alpine Type S coaxials. These are being run off the head unit amp, getting 26 watts. They move, but I have them in for rear fill to be honest. They sound MUCH better than stock, and are overall a very nice speaker for the price, but still leave something to be desired. I had to dremel out the hole in the door to fit the speaker's magnet/motor, and then installed a 3/4" MDF spacer. Paint color leaves something to be desired, all I had was flat black :bang:
In the front doors, I put the Phoenix Gold RSd 6.5s comps. I really like these speakers. For the buck, I don't think there is a better sounding set of speakers in car audio. They are rated at 60w RMS but I have heard of lots of people running them daily at 150w RMS. I am throwing them 60-70 watts at each @ 4 ohms off the Crossfire VR300 (mounted under the front seat. I have the manual seats and no security option, which means I can both mount the amp there and continue to adjust the seats :D) They have a pretty hefty motor for a 6.5" woofer, have roughly 3" mounting depth, and refused to fit in the stock location. I have them secured to the door trim, and no problems so far. I will be putting the stock grills over the old holes, at some point. They required 2x 3/4" MDF spacer rings :doh: Again, paint choice leaves something to be desired. ANy recommendations? Brown/oak? Cover in vinyl? Metalliccy black?
I didn't manage to build a box or install the sub this weekend, but am really looking forward to it. I bought a replacement BBQ grill cover, that with some welding, will cover the entire top of the box so storage on top will still be possible. My last car had two alpine type R 12's, which was way way way too much bass. I have toned it down to 1x 10, designed for sound quality heh.
I took some videos to show the excursion of both sets of speakers. This is just playin off the radio, and I was pretty happy with quality, not so much with the songs on the radio however -
If anyone has any questions, feel free to ask! Oh and btw, jack in the box has these new kiosk things, and when u order, u get 2 free tacos. pretty sweet IMO
What did you do for speaking wiring?
I have a ton of Infiniti gear but I am clueless when it comes to stereo stuff so I haven't installed any of it.
Looks good.
I like the idea of MDF rings to space them out from the door. I took apart a rear door yesterday to look at putting in new 4" Kickers and they are way off. I need to go get some MDF now.
For speaker wire, I used 12ga speaker wire from monoprice. $22 bucks for 100 feet. Really high quality wire, although at the end of the day, its strands of copper through rubber tubing. Point is, don't ever buy into the Monster hype. For wiring, I always choose either monoprice or knukonceptz, whoever is cheaper for the product I need.
For only $19.26 each when QTY 50+ purchased - 12AWG Enhanced Loud Oxygen-Free Copper Speaker Wire Cable - 100ft | 12AWG Loud Speaker Cable
12ga was probably overkill, but it is roughly the same price as the 18ga. Also, I bought 100 feet, but you could probably get away with 50.
The land cruiser was a breeze to wire, seriously. Last car I did was a 1989 735i bmw, which was a total bitch to wire. I just dived in, and wasn't afraid to think creatively about wire runs. I know you are an out of the box thinker nlx, so go with ur gut :P
TO be more precise, I ran it from the driver's seat behind the dash to the right door and through the kick panel to the left door. Crossovers are mounted in the left dash, behind the tweeter/speaker, and in the right dash, again behind the tweeter (where the old amp used to be, to the right of the glove compartment).
Looks good.
Yah, they look alright for sure. But I think a better choice of spray paint or maybe vinyl would be a better choice. The flat black is just bleh. I think my current plan is to spray paint everything metallic black, including the silver alpine grills. ultimately match the black on the PG woofers
I was just thinking of trying to find matching vinyl to wrap the rings with. This will be my next weekend project.
...They have a pretty hefty motor for a 6.5" woofer, have roughly 3" mounting depth, and refused to fit in the stock location.
Sure they will, but it isn't easy. You cannot run the stock grills however. I am running infinity grills. The spacers are covered in closed-cell foam until I find a suitable vinyl to finish the project, which may or may not ever happen.
I too am running an Alpine 9833 HU. The front speakers are running active (no external crossovers, using the crossovers in the HU) with the tweeter running off of HU power and the woofers running at 200W each off of a Cerwin Vega EXL400 amp. I also have an Alpine sub amp running an Infinity Perfect 12" in the rear.
Pic of the PG's in the stock location.
Nice install! care to explain if you modified the window track at all, or if the excursion on the woofers ever contacts the grill? When I put the PGs in the stock location, I couldn't close the door. It looks like you built a lopsided spacer, is that right?
Also, where did you mount the tweets? I have them, like I said, in the stock dash location but am not totally pleased. however, I didn't want to cut up the car anymore
The spacer looks lopsided in the pic, but it isn't. I cut away the hardboard from the back of the door panel and left the vinyl on the front of the panel so the spacer sinks into the door panel. It was very time consuming, and the spacer needs to be thicker than 3/4", and beveled where it meets the 'hole' in the door. I used 2 3/4" spacers gorilla glued together at the face, and planed the thickness down until I got a good fit. It will look better with the vinyl on the spacer to match the panel, and a little more fiddling to get the panel seated better around the spacer. I did not modify the door track at all.
My door panel also sits out a little further than stock because of all of the sound deadening material. There are 2 layers on the outer skin of the door, and one layer on the door where the panel sits, along with a layer of closed cell foam on the inside of the panel.
The woofer excursion did contact the grills when the gain was set too high, but at that point there was distortion present also. I turned them down a bit and now there is no contact and no distortion.
My tweeters are currently stuck to the a-pillars about an inch above dash level with hook and loop tape. I did this so I could move them around until I found where they sound best, which I have not yet determined.
brilliant, I am impressed Ivan! If I ever decide I need another door panel, I will look at re-mounting them in the stock location - though I am still very happy with my install. Just glad to see it can be done =D My favorite thing is stumbling across rigs with similar aspects or goals, and yours is something how I envision mine down the road (I had even thought of the rims :D)
I am amazed we have near identical front stages (you must know a thing or two :hillbilly:) How have you liked the PGs / going active? Did you ever have them passive? I can not imagine how they sound on 200w, they must sing! I haven't pushed my gains at all, about 50%, so I doubt they have seen more than 60w in the last day or two.
What do you have for rear fill / sub stage? Or only got the PGs up front? I saw your rig gets her workouts hunting, bravo! Mine is a hunting/fly fishing mobile (+ DD, but if I could have it my way, I would hunt and fish daily)
edit: one more question - how do you have your equalizer set? ie is there a sweet spot for the PGs? A starting point could shorten my tuning time for sure.
Ive got infinity 6.5" in front, Infinity 4'' in back, and a Pioneer HU. I used the stock amp and speaker wire, even with that severly limiting setup, the speakers rumble the floor board. Of course that after many hours in the car tuning. The temporary set up is not bad and they sing, even with stock wiring and amp.
Very nice set up by the way can't wait till i get my alpine amps and my 10''.
Nice install, gives me some ideas. I've thought of using MDF for spacers and now I see it works pretty good. I was just wondering about the location of the front speakers, it looks like they would go right up against the seats when the door is closed, how is the sound?
I like the mid-bass of the PG's. Overall they are a decent speaker. Not outstanding sound quality, but with 35" mud tires, a Land Cruiser is not the best SQ environment anyhow. I don't have any rear fill, and it could use a little. I may go passive with the fronts and run rear fill off of HU power, like I did in the previous setup.
I have an Infinity perfect 12" sub powered by a crappy Alpine MRP350 amp and I hate it. I'm not a bass-head, but the MRP350 is weak. I was running the sub off of an Xtant 300W class D and it really worked well, until the amp crapped out. I have 2 spare Cerwin Vega EXL350's and I may reconfig my whole system again.
I don't think my EQ settings would apply to you to well (as I cut the 2.5 KHz way down because of running active). I would start with your high-pass filter for the front stage at 50Hz, and low pass to the sub there also. These PG will play down to 40, but mine distort a little there because of the power. I would cut everything below 80 off to the rear fill. If you run the HU in 3 way mode, you could also attenuate the highs to the rear fills to keep the staging up front.
Here's how I would hook it up:
HU set in 3 way mode (there's a switch on the outside case of the 9833)
Front stage (PG's) connected to front amp pre outs
Rear Fill connected to rear-outs speaker wire on HU
Sub - obvious.
Internal HU xover
Front stage - High pass 50 or 63Hz
Rear Fill - Mid L = 80Hz, Mid H = 2.5KHz (reduce the dB here to attenuate the amount of sound coming from the rear. Maybe -6)
Sub - 50 or 63Hz
This may be how you have it now, and as always, YMMV.
:cheers:
Sound is good, certainly as good IMO as the stock location. They are near the seats, but there is 2-3" roughly between the grill and the seat. In the stock location, 1/3 of the speaker is immediately covered by the dash, so its lose-lose as I see it :D As Ivan said, the 80 is not an audiophile's dream. I didn't apply any dynamat and wish I did, it sounds like a tin-can rattling from the outside before the sub is even in.
Sub - obvious.
Internal HU xover
Sub - 50 or 63Hz
:cheers:
Thanks so much for the advice Ivan, I was hoping for some good feedback when I put up this thread. I had similar settings as the ones you mentioned except I was in 2-way mode. I was unsure if 3-way mode worked as you described, but luckily it does, so I'll be rockin that for sure :grinpimp:
GL on changing your sub-amp setup. I really can't wait to hear this RE SE. I know its not the top of their line, but everything else had an RMS over 1000 which was not the direction I wanted to go at all.
I was curious about this "low profile" sub, the RE SL, because you could build such a tiny box. However, 4ohm only versions turned me off - check it out -
Technical Specifications - RE AUDIO
YouTube - Sneak peek of RE Audio SL series 10
After reading all this I shouldve bought better speakers or at least will probably amp the ones I have now.
I do think I will take the 12" Infinity Kappa Perfect sub and Alpine MR650 amp out of my brothers car and put in the Cruiser. That sub is great on the 400W RMS from theamp. Last year at a sound competition he beat some 2-15" setups and all the 1-12" and 2=12" setups with that combo.
I don't think you need new speakers, I would just get a dual channel amp. Run the front stage off the amp, run the rears off the HU for rear fill. that sub and amp combo sounds nasty :clap:
