I've read pretty much all the Aisin hub threads, and don't recall this information:
I have a 1978 FJ-40 with Longfields. I got a set of Aisin hubs from SOR.
The studs that I have don't work. The shoulder (unthreaded part) of the stud is about 13-14mm, but the flange on the Aisin hub is only 7mm thick.
Do I need to get new studs?
SOR lists a kit with studs and cone washers for the Aisins (Part # 080-67-KIT on http://www.sor.com/sor/cat080.tam?xax=20869&page.ctx=cat080.tam).
Do the Aisin's need cone washers? (it looks like the holes may be tapered on the flange)
Do I need '79-later studs (I assume the ones in the SOR kit above would work).
Will those studs thread into my hub (1978) or is there a different thread size? My current studs are 8mm x 1.25
Thanks. Don't want to order anything if it won't fit. Especially since it seems that each kit @ $4.99 only does ONE stud
and I'd need 12 to do both wheels
