Another add a leaf thread
Diamond Valley, Nevada
So what' is the concensus on the best add a leaf for a SOA 40 on flat stock springs? I might also be interested in addind additional leaves to the spring pack, actually might prefer that if they are cheaper. I tried the re-arch and doesn't look like it's gonna last and was a PITA.
Suggestions? Rancho? Summit? Old dude in Amarillo? (search and you'll know what this means:D)
Thanks :beer:
Thanks :beer:
Couldn't find the Amarillo dude. We have an old Missoula codger though! I had him re-arch my stock rear springs a couple years ago. He put an extra leaf in while he was at it, without asking. They rode like a buckboard, as in bone crunching. I'm SUA though. Maybe not a fair comparison.
When searching for a solution to my flatties, I investigated rearching with a local spring shop. They wouldn't do it without installing an add-a-leaf. The cost was approaching just getting new springs($340 + -). I was lucky to have Poser hook me up with a new set of 2" springs + bushings + new shocks for $300.
That made my decision easy.
When I was considering the add-a-leaf, the Rancho was the only one I knew about. Seems like about $50/axle. Don't remember if they came with new pins or not.
HTH
Ed
The old dude in Amarillo is Charles Williams of Texas Spring. Conveniently located only 4 large states away from you. He'd have to have your rig to do it; he does each rig one at a time. Man a Fre sells add a leaves for a 60; not sure about a 40. I think there is more leverage on your (now re arched) leaves due to SOA configuration. I thought most folks liked soft, flat springs on SOA. That's why they say SOA flexes better; easier to flex a flat piece of metal than an arced one. What about pulling a second and/or third leaf from a used pack and adding that?
DocB - thanks for your help, read your thread about Mr. Williams and thought that was really cool, i kinda tried to do the same thing already but I do think I need to add more stock leaves to make it last. I added leaves from a friends '02 F-250 to mine to make it haul better, sounds like I should have taken two rigs to Amarillo ;)
I've made enough trips down there already, it's a long ways for sure. We have good friends who live in Canyon so I know that trip pretty well by now, been about every route there is between here and there. And if I have to take the 40...I might be 50 years old by the time I get there :D
So I guess this thread now = I need stock leaf packs or proabaly second from main leaf or an extra bottom or second from bottom or whatever combination is thought best. My 40 is HEAVY, 35" spare + cooler + aux. fuel tank + camping s*** + fat uhh, passengers :D
Thanks!
I have a set of springs that I just took off. If you want me to, I"ll take them apart and send you whatever you want for the shipping. You can probably find them closer. But you're welcome to mine.
Ed
I just might have to take you up on that offer, will look for a few more days and make some calls. Kurt may have some a little closer, but I'll most likely take you up on that offer.
Thanks a lot, I'll keep in touch.
Now - which leaves? :confused:
