Another '91-'92 Shortcoming....
Boise, Idaho
I've taken care of most of them but could use some help on this...
The wipers don't have an adjustable delay. Anyone add this?
Thinking a duplicate dimmer switch wired in would at least look somewhat factory, but don't know if it's actually feasible.
Anyone have adjustable wiper delay in their FJ80??
They started that in 92. My buddy has that in his 92.
IIRC, Curtis (CJF) replaced his wiper stalk with one from a 94. Says it works great.
AFAIK, it's just an adjustable resistor in the stalk itself. No extra wiring.
My bad, just assumed both '91 and '92 were missing this feature.
Any contact info for Curtis (CJF)? I'd be very interested in this mod.
Thanks,
Mark
I PM'ed CJF. If I end up doing the mod I'll post back with some specifics.
Thanks!
Hey guys!
All I know is I broke my original stalk, called my usual parts guy; he said the part number was superceded by a new one (I wasn't trying to upgrade), and the one he sent me indeed had the variable intermittent feature, and that feature worked with no other mod's. :meh:
In fact, I bought the whole replacement "multi-switch" that had the turn signal, cruise control stalks, etc., since that was truly plug-n-play, rather than trying to separate and connect/disconnect just the one stalk. I'm glad I did, because the turn signal switch had been acting a little wonky anyway, and the new one was like buttah. Oh, and the variable delay really is nice. :)
I'm pretty bad at keeping records, but the following *might* be the part number for the newer multi-switch: 84310-6A110
Edit: Ok, I'm pretty sure the above number is correct. Here's the one from the original switch assembly, which I still have: 84310-6A040.
Cheers all!
Curtis
Hey guys!
Cheers all!
Curtis
Hi Curtis,
Thanks for replying!! So you have a '91 80?
Couple of questions for you:
What exactly was involved with the installation?
You remember how much the newer multi-switch cost??
Thanks,
Mark
Yes, I have a '91.
Installation was removing the steering wheel and unplugging the switch at the big connector below the dash at the base of the steering column (and maybe removing the lower dash trim?). It's very easy.
I really don't recall the price. Maybe ~$150??
It is possible and cheaper to replace just one stalk. That involves pulling the entire multi-switch, then on the bench, disassembling it (LOTS of wires and pin connectors and electrical tape) and removing/replacing just the stalk you want. I could have done it, but was too lazy. :meh: :hillbilly:
Curtis
