Got to start on my 4x4 labs single swingout bumper kit today. Overall it is a nice kit for the $. It fit together well with only minor tweaking and grinding
It is def. a lot of work even though its a kit. Just prepping the frame/demo is a job in itself. Having a second set of hands would have been helpful a few times. Taking the bumper off to finish weld might be a bitch to do solo.
I also discoverd my frame is bent to the pass side about
3/8"-1/2" . Must be from wheeling with a oem trailer hitch before. The bumper fit on nice so I knew the rails where parallel. I plan on going to the frame shop after I am all done for a quick pull on that. The driver side quarter protection is a bit close for my liking.
I took my time on the flares and scribed around the round tubing and cut out everything in the way. I bought the flareless version which has longer wings. Just in case someday I go flareless then the wings are not short.
Here are the pics from then end of the day today. Tomorrow I should get it finish welded, grind, and spray black.
The tire carrier is not in the correct position in pic. Just put it there out of the way. Still need to grind sleeves down so it will fit in correct position.
