- Joined
- Dec 23, 2007
- Threads
- 16
- Messages
- 186
- Thread starter
- #21
Correct. That was a new one for me. In 2019 GM changed to a bigger metric pattern with metric wheel studs. Ford 8 lug has been a metric size since 99
Yep. Friend stole that from some old guy in Idaho. I took out the rear Detroit and put a ARB in for better on road drivability. While it’s here I’m pulling measurements and doing the shell of the roll cage to fit under a hard top until I find another another one. Little jumping around but it all has to get doneThe tan truck in the background looks familiar ?
The Chevy pattern is 8 lug pattern is 8on 180mm. Not sure of the 6 lug pattern. The biggest pattern of all the makes. The 2017 and newer 14 bolts have bigger brakes/wheel hubs/spindles/ bearings than all the previous years.Nope John, they are not, you have the ford 8 on a 170 bc? and the chevy 8 that has a165 bc, almost half a lug stud off, so no interchangeability. so yeah not all the same
Eric, that tie rod and the links look a little light, you may want to beef them up-Been a busy summer helping people get their rigs to the trail. Just got the suspension tacked together, I’m sure some things will need some placement massaging. I pretty much make all my brackets, Universal brackets usually and up to be the same cost wise by the time they are modified to work plus look universal.
Thanks for the tech tip! Trying to save weightEric, that tie rod and the links look a little light, you may want to beef them up-
Dad
