I have brough power from the battery to a fused 6 pole panel mounted under the center council. I brought the power directly to the council from the battery. I am now thinking it would be good to have a fuse at the battery JIC. I figure I will add an in line fuse and call it good. I have added one outlet above the rear heater for the kids dvd's to be run off. I will use a splitter to get power to the two players. I
Now I need to bring power to the rear compartment from the center council. I want to install two outlets in the storage compartment on the PS.
Questions:
I would like to run the power through a switch in the dash to shut the whole system down. Has anyone used a factory switch for this purpose? What switch have you used?
What route did you use to run your power to the rear?
My positive terminal is getting crowded. What have you done to clean it up?
Thanks, I will post pictures as this progresses.
Questions:
