I have searched and read countless threads about idle problems, high idle, low idle, idle with AC, idle without AC, idle in park, idle in gear, ad nauseam. One thing about the threads I've read is that the problems appeared to be a constant issue. Here's where my problem lies. My problem seems to come and go.
My 96 (199,200) runs like a top and idles at a constant rpm without sputtering. Only thing is that the rpm at which it is idling seems to change with no rhyme or reason. After startup/warmup, it will sometimes idle around 900 with the needle steady on the tach. Sometimes, the magic number is 1600-1800 rpm. The other night, after sitting in park for about 5 minutes (while I hunted down an exhaust leak) she settled down to 600 steady rpm. Today, after a 15 minute drive, the idle was a steady 2000!!!
I have lubed the throttle cables, made sure nothing was hanging up, tried with and without AC, tried cold and warm, tried checking it after warmup in the driveway and after driving for awhile.
The temp guage stays just below the center of the guage and never changes despite ambient temp, AC use or driving style. That tells me that my cooling system is in good order.
Could the exhaust leak (loss of back pressure) have anything to do with this? It is really nothing more than a nuisance (other than wasting gas and brake pads) I think, but I'd like to see if I can get it to idle normally so I don't have to fight it at stop lights.
Any suggestions????
Any suggestions????
